Issue with my stang
When starting up my stang, it stalls out the first try but then starts up the second only to chug a little before warming up. My wife said it completely stalled out on her the other day while driving. I just replaced the battery as it died the other day. I also cleaned the air filter and added some fuel system cleaner as it's been a while since I have done so. I'm thinking alternator as we have had problems with the alternator in the past but not sure. Would faulty spark plugs or wires do this? I looked at the plugs some months ago though and they looked fine.
Also, what are the recommended tune up options for a mustang that has over 100K miles on it?
As long as I keep at least a half tank of gas in her she wil run great, but as soon as it starts to get low, she will start cutting out and idling rough.
I'm dreading replacing it and I'm hoping that it will last until I pull the rear end to replace the bearings and install 4:10's. I figure it will be a lot easier to drop the tank with the rear end out of the way...
Just a suggestion. [B-)]
Sue
The gas should be good as I added the fuel cleaner when I had like 1/8th of a tank of gas then put half a tank in the next day.
I've never replaced a fuel pump but have been told how much a pain it is. I'll probably get my dad to help me out if it is needed.
As far as what to do with an engine that has 100k? It is barely broken in.......Fuel filter, plugs / wires. Clean the distributor cap. Keep the oil changed
I would check your fuel pressure-its pretty easy with the valve right on the front of the fuel rail, if memory serves, running pressure is 35 PSI. If you are below that, drop the tank and put in a new fuel pump...as we all know if the pump fails on the street, you'll need a tow truck, and that BLOWS. Also, check for excessive bleed off of the fuel pressure after shutting the engine down. The fuel pressure should remain constant, if it bleeds off quickly, that usually indicates the check valve inside the pump is bad and indicates replacement of the pump. If it does bleed off quickly, thats probably why you are having the cold start problem because there is not enough fuel pressure in the line. The second time you turn the key on, and fire up the pump, is building the pressure high enough to start the car.
I found that having a good transmission jack made all the difference in getting the tank out easily. Also, get the car as high as safely possible on jack stands...you really need the extra room to maneuver the tank, especially if it has several gallons of gas in it-drain out as much fuel as you can before starting the job, it will make it much easier. Really wasn't difficult at all-I did it by myself, but an extra set of hands would have been useful.
Good luck, Tom
