Radiator replacement?
I was poking around on the feature today and noticed that the stock radiator has sprung a leak over the winter. I knew after I bought the car that it was headed south as there looked to be a coral farm growing in it when I flushed and filled it the first time. Well, it has been a year since then and it looks like I am headed for replacement.
Has anybody found a nice stock replacement that doesn't have the plastic end caps? It seems like all the ones I can find of the stock replacement variety (even the Ford Racing one) has the plastic end caps. I have prior history with the one on my 95 Mustang failing so I don't want to deal with seperable end caps. I like the peace of mind that comes from having the end caps brazed to the radiator.
I would hate to move away from the stock look on the feature but I don't see another choice.
I'll call a couple of radiator shops and see what they say.
Unfortunately, the feature got little more than moved around in a shop for six years before I bought it. That didn't help.
So, this shop can get me a new copper/brass OEM look (2-core) radiator for $300. I know that the aftermarket aluminum ones are close to $400 for a good one and that copper/brass are hard to find. Is this a good price?
I decided not to go with the $300 OEM 2-core that the radiator shop wanted to sell me.
I found this one instead: https://www.mustangsunlimited.com/itemd ... =M8005A+01
It's a copper/brass 3-core direct replacement for $170.
Good point. If the radiator was that bad i would go ahead and cut the heater hoses and by-pass the core now before it leaks all over your carpet. Also, as long as you have the radiator out, go ahead and change the hoses and thermostat.
