Looking for...
Anyone know of a source for the clear plastic strip that runs across the top of the windshield? (Where the top rests) I'd post a pic but my car is in the trans shop.
The strip on mine has discolored and I will remove it when I repaint my car later this spring.
I'm not sure of it's importance, but I guess it is there to protect the paint from scratches.
Has anyone removed theirs? If so, have you noticed any problems?
Thanks for any info...
Sue
Sue
He told me the following:
Kevin also attached his installation instructions which are in the form of a file too large to post here. They list NozeGuard as the retailer.
I'll post the results if I find a place to buy it.
Sue [B-)]
Other sources to try locally would be places that apply window tint, etc...
Good luck.
Kevin [B-)]
The product I bought was called "Scotchguard Paint Protection Film", a 3M product of course. It’s a different name as scotchcal, mentioned previously, but other than the name it sounds like the same product made by the same manufacturer. I bought a 4 inch by 84 inch roll for under $25-3M part #84904. I had to go to a Sherwin-Williams automotive paint supplier to get it, but they had everything else I needed for the project (listed below).
Because I'm a novice and too poor to pay $250 bucks to have someone else replace the strip (after all, anyone can pay some else to fix their car, the fun and satisfaction of doing it yourself is part of the hobby), I went the body shop that repairs on our cars at work and asked them how to get the strip off. They told me to use an eraser pad. It’s a round disc that goes on the end of your power drill and removes stickers, pin striping, decals etc (especially those ugly dealer stickers on the back of the trunk). Then they said to use an adhesive cleaner to remove the remaining adhesive residue. My guys even gave me a demo on how to do it-pretty simple once you have the right tools and it doesn't damage the paint at all.
Sherwin-Williams had the pad called a "Smart Eraser Pad" from Astro Pneumatic Tool Company, part #400E, for $14. They also had 3M General purpose adhesive cleaner, part # 08984, for about $9. I'm sure you can buy these things cheaper at Pep boys or AutoZone, but I didn't check it out myself.
I had the old, cracked, discolored strip completely cleaned off, along with the faded old dealer sticker, in about 2 hours. MAN-OH-MAN what a difference. Looks like brand new-Awesome.
I did make one mistake though-didn't get my template done before I removed the old strip. So, I'm currently in the process of creating the template to cut the new film. Also, the installation instructions provided with the new film were identical to those mentioned earlier for the scotchcal product, so I'm guessing it’s the same product, just a different name.
Hope the info is helpful to someone.
Thanks for the info...Gives me another lead to obtain the strip material without having to purchase a huge roll of it...
Also thanks for the heads up on the removal process. I was planning to remove it when I repainted the car, but now I can do it before. It is so discolored that I'm sure it will be a big improvement...
Thanks again for the info, I'm sure I'm not the only one who posts that can use it...
Sue [B-)]
to buy the film itself would only be $20 or so. It's just a matter of whether i try to do something myself to end up paying a couple hundred to have it done properly the first time around. it's not really a straight forward surface to cover by any means.
none of the places that do the kit installations do it cheaply though.
as for sources, various combinations of "3m film bulk" etc will yield places selling it.
http://www.invisiblemask.com/bulkfilm.html for instance.
so far no luck in finding a shop that will do anything but install the pre-cut kits for every car under the sun. no one will do something custom but the search continues.
because the rest of my film was in good shape, he just suggested replacing the end that was damaged so that's what he did. cost way less and wasn't too difficult. he even doubled up the film so this should last a long long time. both ends were done.
before...
after...
