If you frequent wrecking yards don't forget to look on pick-ups.
Vans may have the same length wires too, I don't believe they started with coil-over plugs in vans until around 1996 or so with the Triton plug-blow motors so the 5.0 in the vans should have the same length wires as the Mustangs.
I always forget to look for you when I am in the wrecking yards.
Pics look good ,, they are on the way,,,I will know when I see them uo close. BUT they do have the correct code ! If they look good after I get them I can use them for MCA shows and not lose the points I did this past spring.
