Stereo install question
Ok folks, since I've gotten my grubby mits on an orignal premium stereo setup, I've pulled the POS 90's removable headunit radio. Good news: No cut wires!
Bad news: I have an extra, mystery, plug.
Here's the standard plugs:
And here's the mystery plug that is hanging out back around the amp:
Any idea what the extra plug is for? The aftermarket stereo was plugged into said mystery plug along with the thin grey one of the main harness.
Is the mystery plug supposed to plug into the amp? If so, I can't see anywhere for it to do so.
Does anyone have any suggestions?
Now I wait with baited breath for my stereo to arrive on Wednesday.
I have the pair from a 1988 Thunderbird I had many years ago too and if I remember correctly it has the huge connector on it too. The amp, in the Thunderbird, was in the trunk on the seat divider. I pulled the entire amp wiring to the trunk but squirreled it all away years ago.
I came across the stereo recently and put it aside again.
To all looking in wrecking yards, Aerostars came with this pair of stereo and equalizer too.
I have used Aerostar AM/FM/Cassettes in a couple of my cars over the years. Just swap the bottom cover with a bad Mustang stereo and it goes right into the Mustang console and looks identical. They usually don't have the convertible top-down in the sun faded faceplates on them either.
The other two plugs check out against the pinouts in my shop manual for both the stereo's power and EQ connections.
The radio/EQ I purchased last week should be arriving tomorrow and, hopefully, will be installed and tested tomorrow afternoon.
I've got a bad radio. Damnit!
Amp works fine. EQ works fine. (Tested via plugging my crappy aftermarket radio into the eq/power plugs.
The radio has a serious problem with volume control. I hope the seller can make it right.
