Just found this site and joined. Need help. Got a new (to me) '93 TWF. Power seat will go up & down but not forward & back. My problem is how to remove the seat so I can get to the electronics. I see the 2 forward studs/bolts but I cannot see/find the rear fasteners. Any help is appreciated
Jim
I got the seat out, thank you again. The problem was not the motor or the switch. It was that if you went full forward or aft the screw jack was stripped just enough to cause it to spin without moving the seat. To solve it we moved the seat to a neutral position where the screw jack would engage and it works fine except you have to avoid full forward or aft.
Thanks Again
Jim
P.S. If it is not a lot of trouble I would like that picture in case I need it to replace the screw jacks.
J
Thanks again,
Jim
