I can't seem to find anyone who's willing to help with this...
Does ANYONE have, or have access to a pair of the convertible top tension cable clips for my 93 TWF? These are the small aluminum parts which are on the sides (toward the front) of the top frame. They're typically hidden under the sides of the top in correct installations. They're used to clip the tension cables into.
I need at least one (drivers side), but would prefer both. Please, any and all help would be appreciated, as this is holding up my ability to have the top replaced (and it's shot)...
Photos can be found here:
Thanks!
Anton
Thanks!
Anton
Yup, I called them early on and even a few times after that... They said that they don't have / can't get them and will only sell the entire top frame anyway... They also acted a bit like they couldn't be bothered with the issue...
Anyone else?
Anton
Have you been able to find the Ford Part #? wondering if the clips were sold as part of the cable kit while Ford stocked them?
Please share what you find because I am sure this will be an issue in the future---
I've got the part number for these clips, but they have been discontinued.
E4ZZ-7652724-A
If you have a really good and friendly Ford parts man you might see if he can locate them through there obsolete sources.
Good Luck, Jerry
Any lead is appreciated... I'll give it a shot and let you know how I make out...
Anton
Please let me know if you come up with anything...
Anton
Butler, NJ
Thanks again!
Anton
