Couple of quick questions:
1. What were the stock floormats in the '92 Feature car like?
2. What were the stock tires on the '92 mustang?
3. Also... My passenger side Lock/Unlock dosn't work.. Is there anything that commonly went out or should we just rip it out and start testing it????
Rare_92
Rare_92
Thanks again...
Rare 92
If the locks just won't lock or unlock with the passengers switch it is probably just the switch. Ford didn't use relays so the switches have to take the full load so it is real common for it to be just the switch.
If the door lock actuator in the passenger door isn't locking or unlocking replace it, they are notorious.
Hope this helps, Jerry
Thanks for all your help,
One: it may just be to cool for it to work properly.
Two: you could have a defective pressure switch.
Three: you could be low on freon.
Four: you could have a abstuction in the expansion valve.
A warm day and a good set of A/C gauges should give you a better idea.
Later, Jerry
Are you talking about the passenger switch or the lock itself?
Thanks again Jerry,
Sounds like the switch.
It's a popular switch for Ford you might be able to get it there.
Dealer should also be able to get it.
I bought mine at Fox Mustang Restoration but then I was ordering some other pieces also.
http://www.foxmustangrestoration.com/
