Idle Air Control
                    I received a question from a feature car owner on his car:
                            Unforunately, I rarely run my A/C and when I do it is usually after my car is warmed up in order to keep it in good working order. So, I don't have any first hand experience with it and a cold idle. Anyone have any thoughts?My fast idle when cold stopped working recently. I am guessing that the Idle Air Control isn't working properly even tho it is clean and free to move. I talked to CJ Pony's service department and they said if you start engine when cold and turn on the A/C, the idle should increase if the IAC is working properly. I tried it and it doesn't increase the idle speed. Have you had any experience with this?
http://www.ford-trucks.com/forums/13453 ... stion.html
