Top sag...
                    Hello fellow FE owners,
Ok, it will soon be time for me to replace my top and I have a question about the top.
My concern is with the top frame work. To my, it appears that my the cross bars that run 'door to door' have a bit of negative arch to them. It doesn't show well i pictures so I'm not sure if this is typical.
If it is not the norm, when changing the top, does the shop just straighten then? I have never seen vert top frame parts for sail form the vendors or from repro.
As a side note... I just installed a Astro Performance T-5 built to FRPP Z-Spec... Holy crap is it great. I was starting to loose the syncos in second gear... Ultimately the 1-2 cluster wore a groove in the shift fork and perminatly shifted me up chit creek. :P No second gear at that point, and I had a hard time getting into first gear...
This news trans from Astro is rated 450/330 [>:)] so it should last quite a while. And Tony at Astro was awesome to deal with.
Ok, later,
Tim
Ok, later,
Tim
