does anyone have a 10 disc CD player in the trunk and if so how does it work?
edited September 2005 in Feature Mustangs
I have a ford/sony cd player in the trunk with a remote up front, cant seemed to get it to power up or work.
  • Check your inline fuse & power supply connection to the unit. Use a test light to see if you are getting power to the unit.
    The inline fuse should be located near the changer in the trunk or near where the power supply was tapped to run the unit.
    Hopefully it is just a bad fuse or a connection that has come loose.
  • Thanks didnt know there was one. Im assuming its on the blue wire that runs from the trunk to up front
