Time off=hobby time--door striker repair
It's been a fun week. Today, tackled door striker problem that was causing the driver door to rattle when driving down the street. I thought maybe my hinges were weak at first, but someone knowledgeable pointed out to me that the grey bushing was gone on the door striker which keep the door from moving around.
First pic is the striker which I've already loosened with the torx wrench. There should be a grey bushing over the brass part.
Also notice the black outline--this was recommended to me to outline around the striker to be able to line it back up correctly (so the door closes the same after repair. I used dry erase marker. Grease pencil would work better.
Used lithium grease to grease the door catch and the door hinges (which really needed). Good to go!
Has anyone done this (hinge repair) and how hard is it? If you have instructions – please share. The last thing I want to do is to start a repair and then find out that I cant finish the project or worse - damaged the car.
Kevin
http://www.latemodelrestoration.com/ite ... ushing-Kit
