Whats the best way to put on convertible top boot cover
My car came with no instructions at all on how to install the top cover. And this is my 1st convertible. So how does everyone install their boot covers? Where do you start? Are there any tricks?
I usually snap the button in place on one side, then try to insert the rear same side plastic tabs (carefully and tugging) to get to slide under the car's trim pieces. You'll know the spot to put the plastic tabs under by whether there is a space that accepts them. Once you get it started, makes the rest easier. Then I do the other side (snap buttons and tabs), followed by the back, and finally the front.
Now I'm trying to fix everything and some things I can't. So I'm gonna try to fix it up differently. I've got several things in mind. Hopefully I can get some pictures of before and after.
Thanks for the tutorial on how to put the boot cover on.
This is my preferred way also. Helps get it centered too.
