Beltline mouldings
On my 92 GT convertible, the passenger side beltline moulding behind the door has come /is loose. It can be raised about a half inch.
I am guessing either a clip has come loose or has broken off.
My question is....does anyone know hat holds this trim on? Is it a nut or bolt or as usual some kind of rivet?
Since the boot cover is fastened to this trim, it makes sense it should be tight and not moving around.
Any help would be appreciated.
http://npdlink.com/store/index.php?mode ... lding&pg=2
The places I'm looking say look for a screw holding them in
http://www.stangnet.com/mustang-forums/ ... ce.823032/
The dew wipe (felt black part that wipes the rear 1/4 window) is riveted in I believe.
With the top down you can undo the part of the molding that hangs down. That gave me enough flexibility to lift the front part up to see what the problem was.
There is a bolt fixed to the molding. The nut was missing. With a big washer and a replacement nut, I got it down tight again.
See, if you ask enough questions, you can get some guidance which helps along the way.
Thanks for the assistance everyone.
