toggle menu
TWF Forum
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Activity
Sign In
Register
Home
Feature Mustangs
does anyone have a 10 disc CD player in the trunk and if so how does it work?
teamtruett
September 2005
edited September 2005
in
Feature Mustangs
I have a ford/sony cd player in the trunk with a remote up front, cant seemed to get it to power up or work.
Roughneck
September 2005
Check your inline fuse & power supply connection to the unit. Use a test light to see if you are getting power to the unit.
The inline fuse should be located near the changer in the trunk or near where the power supply was tapped to run the unit.
Hopefully it is just a bad fuse or a connection that has come loose.
teamtruett
September 2005
Thanks didnt know there was one. Im assuming its on the blue wire that runs from the trunk to up front
Sign In
or
Register
to comment.
