Location of Build Sheet ?
                    Does anyone know the location of the buildsheet for the Feature cars?
I am wondering if anyone knows where the sheets are typically located and what will identify a Feature car on the factory build sheet.
www.sspmustang.org / technical has limited information on the sheets for the police and special service cars.
I may have discovered one on my car. Early last summer, a part of my convertible top frame popped out (the large pin that is part of the major hinge on the top frame). It had popped out before but this time it went into the area where the top folds into. It went down real far and I could not reach it from above. I drove all summer without putting the top down while I searched for a replacement. I never found one, but, late in the fall I pulled my back seat bottom in order to see if I could get access to that area. I did get access and found the part.
Best of all, I found several interesting things underneath my back seat. At the time I was putting the car away for the winter so I have been unable to document what I found or investigate further. One thing I found was a sheet sticking out from under the rear seat back. It was stuck pretty good so I did not try to tear it out. I decided to leave it until I have time to take out the seat back carefully. Currently, my car is in the garage with the rear seat bottom out so I just went out and took a few pictures. They came out pretty bad inside the mostly covered car in the dark garage but the two best are below.
At first I thought my "build sheet" was nothing like those on the site you referenced. But, upon further inspection, in the second shot (left side in the shadow) you can see through the sheet to some text on the back. There is a "G" next to what appears to be a printed grid. The back side could be a lot like those on the SSP site.
Once I get the car out for Spring, I plan to get back there and get to documenting it. I will post what I find on my site.
93trplwhtpony & ponydude: you guys have done extensive work with these cars. Do you have any more infomation on build sheets?
